Opfordring til observationer... Spændende!
Indlæg af Jens_Jacobsen » 02 nov 2018, 18:04
Se denne.
Kunne være et spændende emne!
https://www.aavso.org/aavso-alert-notice-655
Re: Opfordring til observationer... Spændende!
Indlæg af nightsky » 02 nov 2018, 19:56
Helt klart Jens
Har uploadet "Lessons from DSLR Photometry of b Per “Third Star” Eclipse (February 2018) Robert K. Buchheim Lost Gold Observatory, AZ" som der nævnes i bulletinen Nok en god ide allerede nu at få skudt sig ind på en eksponeringstid over 15 sek.
FOV
In the case of b Per, there is only one good comparison star nearby, over 17 arc-min from the target
En minimum sampling på FWHM ~ 4 pixels,
With a DSLR sensor, the sampling requirement must be met after the image is “de-Bayered” to select just the Green channels, which implies a FWHM of at least 8-10 pixels before de-Bayering.
God tidspræcision - bedre end 1 sek.
RA/Dec i FITS
Det har været nævnt, op til denne kampagne, at RA/Dec koordinater fra ikke high-end monteringer som gemmes i FITS headeren, nok ikke er god nok til den automatiserede efterbehandling. Det skal vi nok være opmærksom på, medmindre man har en kvalitetsmontering.
Be aware, most of our mount (eq6) is not precise enough to make RA/DEC for any use - e.g. verification or position determination (indeed, have lots of other means to find the object reliably).
RA & DEC are very helpful in the header, but they can be entered manually and not from the telescope communication, which may contain systematic errors. I'd prefer J2000 coordinates. Heliocentric correction calculation using precession is done in IRAF.
- from Peter Somogyi:
